Hartmann846 Posted August 26 Share Posted August 26 The awkward part of moving from an early test weekend into a larger public session is not the new content; it is trusting that the hours you already put in still count. Players who reached the first cap will be watching their ranks, unlocks, and reward progress closely, while anyone still climbing can use Bot Lobby MW4 discussions as a reminder of how much faster focused matches can feel than aimless queue hopping. Progress and installed files are set to carry from Weekend One into Weekend Two, and the cap moves from Level 20 to Level 30. That change matters because the second weekend is not a clean restart. It is a continuation with more room to experiment, more pressure to finish limited rewards, and more reasons to decide where each match fits into your personal target list. Open Beta access does not require a pre-order or a code, so the player pool should also become less predictable. 1 Why Is Progress Carryover the Real Story? Carryover turns Weekend Two into a test of momentum rather than a second introduction. If your rank, weapons, and completed reward steps appear correctly, you can spend your first session learning the newly available maps and attachments instead of repeating the early climb. That is a much better use of limited test time. The practical issue is that players often remember the big reward but forget the smaller thresholds attached to it. There are eight beta rewards spread across both weekends, all intended to carry into the full release if earned. Missing an earlier requirement can make the Level 30 chase feel more urgent than it really is. ◆ Check your level, unlocked items, and reward status before entering a serious match. ◆ Treat any missing progress as a problem to verify early, not something to notice after a long session. ◆ Keep in mind that the Dread Tiger Operator Skin and the Level 30 weapon blueprint represent different kinds of time investment. 2 What Changes When the Cap Reaches Level 30? The jump from 20 to 30 is more than ten extra levels on a profile screen. Higher unlocks usually change how a match feels: more attachment choices can sharpen a weapon's identity, while additional equipment or perk options can reveal whether your Weekend One setup was genuinely strong or simply comfortable. There is still no confirmed detail on the XP curve from Level 21 through Level 30. That uncertainty should affect how you plan. Do not assume the final stretch will move at the same pace as the opening levels, especially if later ranks require more match time or reward performance rather than simple participation. ◆ Use the first few matches after Level 20 to test one new option at a time. ◆ Avoid rebuilding every loadout at once, since you will not know which change actually improved your results. ◆ If a mode gives reliable XP while letting you complete multiple tasks naturally, it is probably worth more than a flashy mode that produces uneven matches. For returning players, the cap increase also fixes a common early-access frustration: hitting Level 20 just as you begin to understand a weapon's recoil rhythm, map routes, and ideal engagement range. Weekend Two lets you push past that plateau. For newcomers, it offers a fair chance to catch up, but only if you play with a purpose instead of constantly changing modes after every rough round. 3 Which Rewards Deserve Your Attention First? The best priority is not always the reward that looks most impressive. Start with requirements that can be completed through normal play, then move toward goals tied directly to the Level 30 ceiling. This reduces the risk of spending the whole weekend chasing one item while leaving easy progress unfinished. 1) Make a quick note of every reward you have already secured. 2) Identify the nearest unfinished target and pair it with your preferred XP mode. 3) Reserve longer sessions for the final levels, when the pace may become less forgiving. It is also worth leaving space for the new maps. A beta is where routines get challenged. A route that felt safe during Weekend One may become a liability once more players understand sightlines, spawn flow, and the strongest positions. Re-testing your habits with higher-level gear is more useful than merely repeating the same successful match pattern. 4 How Should You Spend the Opening Hours of Weekend Two? Log in early on August 28, but do not rush straight into a full grind. Give yourself enough time to confirm that the transfer worked, inspect fresh unlocks, and run a few matches with low stakes. Those opening games are where you can tell whether your old class still fits the updated environment. If your only goal is Level 30, play deliberately: choose a reliable mode, stay through complete matches, and avoid switching plans after one poor result. If you are more interested in learning the game before release, divide the session between progression and experimentation. Both approaches work; the mistake is pretending you are doing both while accomplishing neither. Players tempted by a cheap CoD MW4 Bot Lobby should remember that the public beta's real value is understanding live-player pressure, map pacing, and your own decision-making. Use the extra ten levels to build familiarity, secure the rewards still within reach, and enter release day knowing which playstyle actually holds up. Quote Link to comment Share on other sites More sharing options...
