Hartmann846 Posted August 26 Share Posted August 26 The Dig event is entering its closing stretch, and that changes what smart Monopoly GO players should value. If you are checking Monopoly Go Stickers while trying to stretch a dwindling dice pile, the real pressure point is usually Pickaxe supply: every unclaimed tool can become a board clear, a dice payout, and one more useful push through the active rewards. Farming Treasures, also known as Crop Circle Treasures, is expected to remain live until around August 26, 2026, at roughly 1:00 PM ET, so this is no longer the moment for perfectionist digging. Play the Clock, Not the Perfect Board Early in a Dig event, it makes sense to protect Pickaxes and hunt for the most efficient tile pattern. Near the close, that mindset can leave rewards sitting behind unfinished boards. A completed board matters more than an elegant excavation when there may not be enough time or tools left to revisit it. The event's board progression creates a simple but harsh trade-off. Later layouts are often larger, less forgiving, and more likely to absorb a pile of Pickaxes before revealing the last treasure tile. If you are already partway through several boards, pick the one with the clearest remaining target rather than spreading tools across all of them. ◆ Count your available Pickaxes before committing to a dense board. ◆ Favor boards where revealed spaces have already narrowed the treasure's possible locations. ◆ Treat a near-complete board as a reward package, not just another digging puzzle. That last point is easy to underestimate. Board completion can return dice and event rewards that feed back into tournament play, milestone progress, and the next day's Partners preparation. Leaving three boards half-open may look flexible, but one cleared board is usually the result that actually moves your account. Where the Closing-Hour Pickaxes Come From Your remaining digging attempts are not limited to what is visible on the event screen. The current Beam Up Bonanza milestone track, tournament placement rewards, Quick Wins, and shop gifts can all add tools, sometimes in small amounts that become meaningful when a board needs only a few more hits. Before spending dice, take a minute to check which reward source is closest to paying out. A tournament threshold requiring a modest point total can be better value than chasing a distant milestone, especially if your board is one treasure away from completion. This is where experienced players stop thinking in terms of "more rolls" and start thinking in terms of "what unlocks Pickaxes fastest." 1) Collect every free reward currently available before rolling. 2) Check the closest milestone and tournament thresholds for Pickaxe payouts. 3) Use Quick Wins as a low-pressure source of progress if their tasks are nearly complete. Keep roll multipliers controlled while doing this. A high multiplier can create a satisfying burst of points, but it can also drain the dice needed to reach several smaller reward checkpoints. In the last hours, steady progression tends to outperform one expensive swing that misses the right tiles or lands you short of the next payout. Read the Board Like a Puzzle, Not a Lottery Dig boards reward deduction more than blind tapping, particularly once a few empty tiles are exposed. Large treasures cannot fit everywhere, and their placement rules become much easier to read when an edge or corner has already been cleared. Start from areas that rule out the most possibilities, not merely the spots that feel lucky. Edges are especially valuable when you are searching for a long object. A revealed empty square can erase several possible placements at once, while a hit near a boundary can tell you how a treasure must be oriented. This approach saves tools because every miss still gives usable information. ◆ Probe edges first when a large treasure has limited legal positions. ◆ Use empty tiles to cross off every placement that would overlap them. ◆ Shift to isolated unknown squares only after the larger shapes are constrained. Exploding critters are the exception to cautious targeting. When one appears beside several unrevealed tiles, triggering it can be worth more than another precise hit because it breaks open a chunk of the board and may expose a treasure's direction. Do not trigger one just because it is there, though; its best use is clearing a crowded area or reaching stubborn spaces that would otherwise demand several separate Pickaxes. Choose the Reward That Still Helps Tomorrow There is a temptation to keep digging until every board looks clean, even when the remaining treasure is buried in an awkward cluster. Resist that impulse if another board is easier to close. The immediate dice reward from a completion can be more useful for the rest of Beam Up Bonanza than a costly attempt to solve the hardest remaining layout. Think about your wider account position as well. Players with a healthy dice reserve can afford to press tournament milestones for extra tools. Players running low should prioritize free claims, manageable Quick Wins, and boards that can realistically be completed without exhausting their reserve before the Partners event arrives. ◆ High dice reserve: chase efficient Pickaxe milestones, then finish the most advanced board. ◆ Low dice reserve: claim free tools first and target the easiest completion available. ◆ Uncertain board state: spend one or two probing hits only where they remove several possible treasure positions. If you are also planning trades or trying to complete albums between events, Monopoly Go Stickers for sale can be part of the wider collection conversation, but do not let album planning distract from tools already waiting to be claimed. The best closing-hours play is still practical: gather every Pickaxe you can, finish the boards within reach, and preserve enough dice to enter tomorrow's event cycle with options. Quote Link to comment Share on other sites More sharing options...
