luissuraez798 Posted August 3 Share Posted August 3 Life of a Pharmacist is one of Arc Raiders' best examples of a quest that looks harmless on the logbook, then gets tense the second you touch the front door. You're heading into Buried City for four quick documentation prompts, not a long loot grind, yet the approach can turn ugly fast; treat your ARC Raiders Items as expendable support for a focused run, because lingering outside Arbusto Farmacia is usually where a simple job goes wrong. The actual mission route Lance offers Life of a Pharmacist after Espresso, which itself follows Bees!. Once it is active, head for Arbusto Farmacia around Piazza Arbusto in eastern Buried City, near the collapsed highway. The green pharmacy sign is your visual confirmation. The main entrance must be forced open, and that noise changes the whole pace of the raid. Don't arrive thinking the upper floor is dangerous because of its puzzles; it isn't. The danger is that other Raiders may hear the entry and decide the pharmacy is worth checking. Four prompts, one clean sweep Go upstairs immediately after entering. The targets sit in a sensible sequence, so there's no reason to circle the building or search every room. From what I've seen, the prompt can be picky about where your reticle rests, especially on the smaller decorative targets. Slow down for a second at each object, let the interaction complete, then move on. The intended order is 1 photographs for family, 2 piano for skills, 3 potted plants for hobbies, and 4 the table near the next staircase for taste. Objective What to inspect Practical cue Family Framed photographs Top of the stairs Skills Piano Same upper living area Hobbies Potted plants Adjacent room Taste Table setting Near the second staircase Do this, not that The smart play is objective first, containers second. Don't spend the opening minute rummaging through pharmacy shelves while your quest targets are upstairs and the entrance has already announced your presence. If you intend to buy ARC Raiders Loot for later loadout planning, keep this mission's risk profile in mind: expensive gear does not make four fixed interactions faster. A cheap, mobile kit gives you more freedom to reset after a rough spawn. Pause before forcing the door and listen for footsteps or ARC activity nearby. Move upstairs without stopping for side loot. Check the quest tracker after the fourth interaction. Stay away from windows while deciding how to leave. Only search the building if the street sounds quiet and your inventory has room. Extraction is a separate decision The documentation steps register without extraction, so completion and profit are two different goals. That matters more than most guides admit. With an empty pack, finishing the table prompt means you can prioritize survival routes instead of forcing a station exit just because it is close. With medical supplies, keys, or valuable materials in your bag, your priorities flip: stop rushing, listen at the doorway, and choose the least active route you can read. A nearby exit is convenient, not automatically safe. Why this quest sticks with players Arc Raiders often sends you after components, supplies, and combat-adjacent objectives. Life of a Pharmacist does something more personal. The photographs, piano, plants, and table turn Arbusto Farmacia's upper rooms into a sketch of someone's old life rather than another building full of possible loot. Lance's request may sound light, but the contrast lands: you're preserving traces of an ordinary person while making noise in a dangerous district. It is short, but it teaches a useful Arc Raiders habit-finish the mission condition before greed turns a clean run into a recovery screen. Quote Link to comment Share on other sites More sharing options...
