luissuraez798 Posted August 3 Share Posted August 3 The smart way to handle Life of a Pharmacist in Arc Raiders is to treat it as a fast objective run, not a shopping trip. Arbusto Farmacia can tempt you with shelves and side rooms, but the real prize is completing Lance's four documentation prompts before the building turns into a pressure cooker; pack only what supports that plan, even if you were browsing ARC Raiders Items for a bigger run beforehand. The Route That Actually Saves Time Head to Buried City's eastern side, around Piazza Arbusto and the collapsed highway, then watch for the green pharmacy sign. The entrance needs to be forced open, which is why lingering outside is often worse than committing quickly. Once you enter, your route should stay tight and predictable. 1. Open the marked pharmacy entrance and move straight inside. 2. Find the interior staircase leading to the residential floor. 3. Document the framed family photographs at the top. 4. Turn to the piano, then move into the adjacent room for the plants. 5. Finish at the table near the next staircase and check your objective log. That order matters because it follows the rooms naturally. Players lose time by circling back for the table after inspecting every container, and every extra second inside gives nearby Raiders more time to react to the entrance noise. Don't Treat the Door Like a Minor Detail The building itself is easy. Getting through its front door without advertising your position is the part that deserves respect. Before opening it, stop behind cover, listen for footsteps, and scan windows plus the street behind you. Then commit. Half-peeking the doorway repeatedly is usually how a simple quest becomes an awkward close-range fight. Once upstairs, prioritize prompts over loot. The photographs, piano, potted plants, and table are environmental objects, so aim directly at the item instead of waving your crosshair around the room. From what I've seen, the plant objective is the one players miss most often because it blends into ordinary décor rather than looking like a major quest marker. Low-Cost Kit or Full Loadout? Life of a Pharmacist doesn't demand high DPS, expensive gear, or a min-max build. Since the documentation steps can register without a successful extraction, a lower-cost loadout makes sense for a quest-only attempt. That changes if you intend to turn the pharmacy into a loot stop; browsing ARC Raiders Items for sale might suit a broader Buried City plan, but it shouldn't convince you to overpack for four fixed interactions. Your Plan Best Approach Quest progress only Move light, finish prompts, leave quickly. Quest plus loot Keep inventory room and reassess after completion. Several Buried City tasks Bring stronger gear only if the other objectives justify it. What I Wish More Players Did After the Last Prompt Don't sprint into the street the second the final interaction completes. Pause upstairs for a few seconds, stay off obvious windows, and listen for movement around the entrance. The nearby station may offer an exit option, but a close exit can also attract the same players who heard you force the pharmacy open. Quest complete does not mean danger over. A useful decision rule is simple: empty pockets mean prioritize distance, while valuable medical supplies or rare materials mean slow down and choose the safer departure. Arc Raiders rewards restraint here. A clutch extraction feels great, but refusing a bad fight after finishing your task is often the better play. Why This Small Quest Sticks With You Lance sends you through a ruined pharmacy to document a person through photographs, music, plants, and a table setting. That's a more human objective than another component grind, and it gives Arbusto Farmacia a personality beyond its loot value. Completing it also opens Tribute to Toledo and A Toxic Trail, so the reward package matters less than the new routes it creates. Finish Espresso, accept the task from Lance, follow the upstairs sequence, and let the pharmacy tell its story before you disappear back into Buried City. Quote Link to comment Share on other sites More sharing options...
