terrapinjam99 Posted May 2, 2025 Share Posted May 2, 2025 Hello , I just purchased a used 2022 Special QM, Baked Maple, Solar is actually " floating " , and it not supposed to be floating like that. The block is not sitting against the wood inside the cavity. As such - the D-Tuna cant work the way its supposed to because when you push down on D-Tuna it pushes the whole assy down. So I am looking for some input on this. I am not sure if the previuos owner changed it to floating, but these are supposed to be setup to where you can ONLY push down ( dive ) the Floyd. I am looking for any input on this. Thanks Quote Link to comment Share on other sites More sharing options...
BOZO Posted May 5, 2025 Share Posted May 5, 2025 here is the manual, this should help https://www.fmicassets.com/Damroot/Original/10003/EVH Wolfgang Special Owner's Manual.pdf Quote Link to comment Share on other sites More sharing options...
terrapinjam99 Posted May 7, 2025 Author Share Posted May 7, 2025 Thanks, so yes that confirms that this Wolf Special should be " dive " only ( and not floating ) per the manual , but is that achived by the back of the Floyd decking against the body - OR by the trem block inside the cavity butting up again the body inside the trem cavity ? Wish I could see the inside of the trem cavity of a Wolfgang as it should be ( ie dive only )so I can see how that is achived out of the factory. Im just wondering why this one that I just purchased is floating? Thanks Quote Link to comment Share on other sites More sharing options...
BOZO Posted May 10, 2025 Share Posted May 10, 2025 you can also try lowering the Floyd's studs, until it fits into the carve out https://www.sweetwater.com/sweetcare/articles/floyd-rose-setup-guide/ Quote Link to comment Share on other sites More sharing options...
