My Floyd is " floating " ?
Hello ,
 I just purchased a used 2022 Special QM, Baked Maple, Solar  is actually " floating "  , and it not supposed to be floating like that.  The block is not sitting against the wood inside the cavity.  As such - the D-Tuna cant work the way its supposed to because when you push down on D-Tuna it pushes the whole assy down.    So I am looking for some input on this.   I am not sure if the previuos owner changed it to floating, but these are supposed to be setup to where you can ONLY push down ( dive ) the Floyd.     I am looking for any input on this.   Thanks
Thanks,    so yes that confirms that this Wolf Special should be " dive " only ( and not floating ) per the manual   ,  but is that achived by the back of the Floyd decking against the body - OR by the trem block inside the cavity butting up again the body inside the trem cavity ?   Wish I could see the inside of the trem cavity of a Wolfgang as it should be ( ie dive only )so I can see how that is achived out of the factory.    Im just wondering why this one that I just purchased is floating?
Thanks
